Maybe you should rather clarify what you want to do with this Server?
I am asking because dual i5's isn't a thing and dual CPUs is generally not something i'd recommend in a time where 16 core CPUs exist
for consumer.
With 3 PCIe Lanes i guess you mean 3 PCIe 16x slots, right?
Also, what's your budget?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1443376-help-building-a-server/#findComment-15481579
1 hour ago, henriquearaujo806 said:
Hi
So i want a server and I'm undecided on buying a full server or build up one myself. What do you advise?
My requirements are:
  • Dual CPU (Xeon or i5);
  • Redundant power suply;
  • At least 3 pcie lanes;
Thank you
These are very strange requirements. What are you using it for?
https://linustechtips.com/topic/1443376-help-building-a-server/#findComment-15481663
So, im planing to run proxmox and then run some vm's, such like home assistant, plex, ubuntu server, jellyfin, pi hole, etc...
For the 2 CPU choice, its because i need to have good performance and a lot of cores, in order to allocate them to the vm's.
About the redundant power suply, I want that feature because i want to conect the first one on the grid and the second one on a UPS, for security.
I also want to have at least 3 pcie lanes (Yes, PCIe 16x slots) in order to add more equipment when needed.
Thank You
https://linustechtips.com/topic/1443376-help-building-a-server/#findComment-15484682
Thank You
I think you are vastly overestimating what you think you need for cores. Vm's can share cores without issue.
https://linustechtips.com/topic/1443376-help-building-a-server/#findComment-15484956
Absolutely no need for dual CPU, if you're using a decent enough CPU.
home assistant, pihole, ubuntu (just the OS) are very low usage and can easily share a few cores.
Jellyfin/Plex, if you have hardware transcoding then like 2 cores is enough...if you're doing software (CPU) then you can probably get by with 4 if its just a couple of transcode streams at a time. Outside of transcoding it really just needs the cores for transcoding audio, library scraping/metadata, and intro detection (plex)
I assume you mean 3 PCIe slots
What is your budget for this server?
Since you're planning to run proxmox and run a media server, are you going to be doing ZFS or LinuxRAID? Or do you want a RAID card as well?
How much storage are you after?
What's the point of redundant PSU's for a home hobbyist server like this? There are redundant ATX PSU's but theyre prohibitively expensive, so you'd really be restricted to enterprise server barebones/systems.
Do you require a rackmount?
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1443376-help-building-a-server/#findComment-15485097
