Which CPU Cooler would be better?
Go to solution Solved by Anthony10,
I think my initial thought of the H75 will perform better, I was looking for some reassurance and I've got that from 2 people, so we'll have to see when I build it if I run into problems.
I would like the quieter and higher performing CPU Cooler.
I'm deciding between:
Noctua NH-L9i
and
Corsair H75 with a Slim 12mm Thick Scythe Slipstream Fan in pull, which is rated at 1mm/h20.
Which would cool better and quieter?
Are there any better options that are under 83mm in height?
https://linustechtips.com/topic/144337-which-cpu-cooler-would-be-better/
The Noctua cooler would be quieter and likely cool better.
Nope the H75 would be better at cooling.
Noctua all the way.
Nope the H75 would be better.
According to this review, http://www.hardwaresecrets.com/printpage/Corsair-H75-CPU-Cooler-Review/1834 , the H75 would be better. The fan will be louder at stock, this wouldn't be a problem since you are going to get a new fan. Also don't get a slim fan, they are not very good.
Quote me to get a reply!
It doesn't fit without a slim fan, so please respond based on what I said. This will be in the Raven RVZ01 which has 83mm height clearance on the CPU cooler.
If you can't get a 25mm fan then don't bother. I would go with the L9i instead.
Actually I found this, http://www.frozencpu.com/products/21926/cpu-scy-38/Scythe_BIG_SHURIKEN_2_Rev_B_5-Heatpipe_Universal_Low_Profile_CPU_Cooler_SCBSK-2100.html . I believe this would be better. The fan is designed for the cooler so I think it should be fine.
As I said it has 1mm H20 so it is a good rad fan.
