What will you use it for?
Is there already an idea for an upgrade path or why the high end CPU and mid tier GPU?
What's up with the weird monitor setup?
EDIT:
If you were to ask me about this PC purely for gaming i would:
- Get a different, cheaper, CPU
- Cheaper motherboard,
- Cheaper Case
- Better graphics card (or if you can, wait for 4000 Series)
- throw that HDD away and replace the 1TB SSD by the 2TB version
- Get one good 1440p 165hz monitor
- Go Aircooling although i understand working with an AIO is easier.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1443216-building-a-pc/#findComment-15480586
EDIT:
- Cheaper Case
I am using it for gaming
https://linustechtips.com/topic/1443216-building-a-pc/#findComment-15480627
37 minutes ago, Nyuuthi said:
I’m trying to build my first pc, can y’all give me feedback for my parts?
link: https://pcpartpicker.com/list/ZXZCFg
Id go with a 12700k, 360 aio and a 6600xt if its just for gaming, that monitor setup looking a bit sus ngl
Main:
  • CPU
    10700k 5ghz All core 47 ring ratio 1.275v
  • Motherboard
    MSI Z590 A Pro
  • RAM
    4x8 viper steel samsung bdie: 4200-17-17-30
  • GPU
    Gigabyte RTX 3080 Gaming Oc
  • Case
    O11 air mini
  • Storage
    970 Evo Plus 500gb OS, Sn550 1tb, 860 evo 500gb, 2tb MX500
  • PSU
    RM750x (2018)
  • Display(s)
    Acer Nitro vg272up, Kogan 24 1080 120hz
  • Cooling
    arctic 280aio, EK M.2 NVMe Heatsink on 970 evo plus
    Second:
    Cpu: i5-8400
    Cooling: ID-Cooling Frostflow 120x
    Ram: 2x8gb 2666 c16 hyperx fury, tuned the absolute balls out of it but def not stehble.
    Mobo: Asus Prime H310M-K
    Gpu: Igpu
    Case: Coolermaster MB311L
https://linustechtips.com/topic/1443216-building-a-pc/#findComment-15480636
ok.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1443216-building-a-pc/#findComment-15480784
What is with those monitors ? Are you just using one monitor for gaming, and the other two as non gaming screens ?
That is a very unbalanced build for gaming. You are spending $3100 and only getting an RTX 3060.
Something like this for example has an RTX 3080 and still gives you $1200 for monitors. I haven't included Windows as you could look at buying a code instead of paying $100+ for it. Places that sell game codes usually sell windows keys.
PCPartPicker Part List
CPU: Intel Core i7-12700F 2.1 GHz 12-Core Processor  ($312.95 @ Amazon)
CPU Cooler: Scythe Fuma 2 Rev.B 39.44 CFM CPU Cooler  ($65.98 @ Amazon)
Motherboard: Gigabyte B660 GAMING X AX DDR4 ATX LGA1700 Motherboard  ($169.99 @ Amazon)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($145.93 @ Amazon)
Storage: Intel 660p 2.048 TB M.2-2280 NVME Solid State Drive  ($149.99 @ Newegg)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Video Card: Gigabyte GeForce RTX 3080 10GB LHR 10 GB GAMING OC Rev 2.0 Video Card  ($759.99 @ Newegg)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($94.99 @ Amazon)
Power Supply: Thermaltake Toughpower GF1 PE 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Total: $1839.80
Generated by PCPartPicker 2022-07-14 18:36 EDT-0400
https://linustechtips.com/topic/1443216-building-a-pc/#findComment-15480962
