Cooler Question
Go to solution Solved by emosun,
8 minutes ago, MRkingbacca said:
If I left the air cooler in freezing Temps would it break, because it uses water to draw away heat
It'll be fine , there are no temps an air cooler would encounter that would be a problem for just the cooler and not every other object around it.
I believe gas filled heatpipes do not have enough material inside them to expand beyond the integrity of the pipe itself even when frozen
https://linustechtips.com/topic/1441268-cooler-question/#findComment-15467173
Heat pipes don’t like the cold too much. -15-20c they don’t work so well.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1441268-cooler-question/#findComment-15467224
