Hey y'all! I'm in the market for a case and I really want a pink one to match my room+setup, what good cases would you recommend that support a full ATX board? I like the coolermaster NR200P but it doesn't support atx, I'd also like something with a little bit better airflow. Looking for something in the $100-200 range but that's not a super strict budget.
https://linustechtips.com/topic/1440449-pink-case-suggestions/
i think your going to have to get rid of all your wants and just be happy to get a pink case... there will be a chinneses pink case some ware with crap air flow probably.
https://linustechtips.com/topic/1440449-pink-case-suggestions/#findComment-15461398
23 minutes ago, BiotechBen said:
Vetroo A03 pink?
that case is at least not too garbage
https://linustechtips.com/topic/1440449-pink-case-suggestions/#findComment-15461432
4 minutes ago, tkitch said:
hmm that one would have a good build qulaty
https://linustechtips.com/topic/1440449-pink-case-suggestions/#findComment-15461452
