monitors Monitor display difficult to see at dark setting.
Solved by Andrewtst,
I believe this monitor must be use for quite some age.
Sorry to tell you this is start of the end of the monitor life span.
It will eventually spread to entire screen later.
I face many before, one is mine, 30 to 40+ belongs to company monitor and I know this is the end road.
** I work in enterprise company and my company had at least 2500+ PC, which means the monitor is more than 2500+ as some is using dual monitor.
Is time to source for a new monitor.
