Fan Controller
Go to solution Solved by loccilucas,
Just use something like this http://www.quietpc.com/gel-pwm-1-4-pwmcable
Hey guys,
I'm looking for a internal fan controller. I haven't been able to find any like I want.
What I want is a module(do know what to call it) where i plug in my fans(4 pin) and I want a usb cable from the module i can plug in directly on my motherboard so I can control them with a software. Anybody know of such product?
https://linustechtips.com/topic/143997-fan-controller/
how many fans do you want to control?
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/143997-fan-controller/#findComment-1922981
Hey guys,
https://linustechtips.com/topic/143997-fan-controller/#findComment-1923014
aquaero xt does this.. but it's like 200-300$ :q
https://linustechtips.com/topic/143997-fan-controller/#findComment-1923028
https://linustechtips.com/topic/143997-fan-controller/#findComment-1923045
