Hey guys of the LTT forum
Recently my AIO failed and I am now quite desperate for a cooler
I looked at the noctua nh d15 but my ram is the corsair vengeance聽
Does anyone know of a cooler that will fire sure cool my 3700x to low temperatures in the h7 flow
I would really like it to not be water and instead air馃挩馃挩
https://linustechtips.com/topic/1438855-cpu-cooler/
I use an Icegiant cooler for my 3950X and it works great.
Pricey but worth it in my experience.聽
This is it: https://www.icegiantcooling.com/products/prosiphon-elite
"If you ever need anything please don't hesitate to ask someone else first"..... Nirvana
"Whadda ya mean I ain't kind? Just not your kind"..... Megadeth
Speaking of things being "All Inclusive", Hell itself is too.
https://linustechtips.com/topic/1438855-cpu-cooler/#findComment-15450163
DeepCool AK 620. Basically a cheap Noctua.聽 Don't get that Corsair one, whatever you do.聽 How much clearance do you have?聽 What is your memory,聽 LPX?
Priced at$69.99, the AK620 also undercuts some of its largest rivals in price and performance comparisons, and sticks to a no-frills design mantra of satin black fans, handsome heat stack top pieces, nickel-plated cooling towers. This cooler is a must-buy if premium $100 heatsinks are a bit beyond your budget.
Edited by JKRsega
https://linustechtips.com/topic/1438855-cpu-cooler/#findComment-15450177
A quick Google search suggests 45 mm
https://linustechtips.com/topic/1438855-cpu-cooler/#findComment-15450203
4 minutes ago, JKRsega said:
No, I meant in your case. 160mm is required for that cooler.聽 What specific model of ram do you have?
It's the h7 flow from nzxt, I already ordered the cooler you suggested, so now I'm just waiting, hopefully it'll arrive asap
https://linustechtips.com/topic/1438855-cpu-cooler/#findComment-15450216
53 minutes ago, DeeBeeSee said:
Ty for the quick responses but I don't have 100+ bucks to spend, if someone knows anything under like 90 $ and still have enough clearance for the corsair vengeance it would be amazing
Get a scythe fuma 2 then. About 60$ and more than plenty good to cool a 3950x.
https://linustechtips.com/topic/1438855-cpu-cooler/#findComment-15450250
Gamers Nexus rated it highly and we know they don't hold back.聽 Also, your case has 185mm of CPU clearance, so it'll fit easy.
Edited by JKRsega
https://linustechtips.com/topic/1438855-cpu-cooler/#findComment-15450704
@DeeBeeSeePlease do not buy the current ProSiphon (its simply not competitive with other air coolers), the new copper coldplate version that probably will be is just about to hit market.
https://linustechtips.com/topic/1438855-cpu-cooler/#findComment-15450745
