Hello everyone,
I decided to buy a ups, but I cant find how much watts my pc is using. every calculator I found online is showing me drasticly diffrent numbers. I would be very thankfull if someone can tell me how many watts in a ups I need for my pc.
my specs are:
i7-6700k
gtx 1070
16gb ddr4
2 ssd+ 1 hdd hard drive
https://linustechtips.com/topic/1437819-choosing-a-ups/
You can look up the specs and estimate for each part, or you can use a tool to measure how much of a load your system draws.
The old brand I know of is p3 International Kill A Watt, but I am sure there are others that can tell you exactly how much your system is using.
https://linustechtips.com/topic/1437819-choosing-a-ups/#findComment-15443203
You're overthinking it.  What is the rating of your PSU?  Assume 80% efficient, so multiply the rated output by 1.2--which gives you a rough SWAG about the total draw the PSU requires.  Then add the power draw for all other peripherals not running off the PSU (monitors, etc).
Add 10% overhead to the total figure as a margin of error.  That will give you the wattage you need.  Keep in mind that UPS's are listed in VA--which is not the same.
https://www.eaton.com/us/en-us/products/backup-power-ups-surge-it-power-distribution/backup-power-ups/va-versus-watts--eaton.html
https://linustechtips.com/topic/1437819-choosing-a-ups/#findComment-15443209
I've found that for the vast majority of users looking for a simple UPS for a single gaming desktop that'll allow them a graceful shutdown period in the event of a power outage, a basic APC/Cyberpower 1350-1500VA unit is sufficient.
I like this CyberPower unit for $220.
https://www.amazon.com/CyberPower-CP1500PFCLCD-Sinewave-Outlets-Mini-Tower/dp/B00429N19W/
The VA rating involves some math but you don't have to be perfect, having too much capacity isn't bad. Hell i've used my UPS to keep my phone and other electronics topped up over a weekend with no power last year.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1437819-choosing-a-ups/#findComment-15443232
