Custom case help
Go to solution Solved by brob,
6 minutes ago, Rob Kinsey said:
Ideally maybe go a little darker. Was thinking just a varnish? Or is there something special I should use because it’s a pc case
You shouldn't need anything special. I would avoid finishes that were prone to holding static charges. Dust resistant finishes would be preferred.
Hey all,
Not sure if this is the right discussion group, sorry in advance.
building a new media/gaming centre for the lounge. All bits bought but I’ve decided to build a custom case. My question is once this is finished & sanded smooth (please see photos) what should I treat with.
Many thanks,
Rob
https://linustechtips.com/topic/1437813-custom-case-help/
well that depends, different finishes leave very different colours on the wood.
what do you want out if this?
https://linustechtips.com/topic/1437813-custom-case-help/#findComment-15443159
https://linustechtips.com/topic/1437813-custom-case-help/#findComment-15443174
https://linustechtips.com/topic/1437813-custom-case-help/#findComment-15443190
