Hi, I have this 2 months old set up:
I5 10400f
Biostar h510mph
6600xt red devil
cooler master g700 gold
I noticed while playing warzone without earbuds that the cpu fan is going loud on and off
On msi afterburner , while gaming:
cpu temp was hovering between 75 and 85c (max 88) at 40-60% usage, power draw 50-55w, all core have similar usage and temps clock speed (4006)
GPU usage 90% with 61c temp
On idle
CPU temp  was hovering between 40 and 60c (max 66) at 10-15% usage, power draw 17-22w, all core have similar usage and temps and clock speed (4006)
What's the issue, I removed the tempered glass side panel for more air flow and put case fan to max speed but nothing worked.
The temps were normal a while ago, I remember idle temp was 30-35c.
I'm suspecting its because of thermal paste but the CPU is just 2 months old and brand new, can thermal paste wear out that quickly?!
https://linustechtips.com/topic/1436638-i5-10400f-high-temps/
11 hours ago, Schnoz said:
What cooler are you using? It seems to be an issue with the thermal paste or mounting pressure. Double-checking your mount, and reapplying paste with some Kryonaut, should help.
yea stock cooler, I turned off the pc and after 12 hours. The temps are back to 30c at idle, maybe cuz its summer time
https://linustechtips.com/topic/1436638-i5-10400f-high-temps/#findComment-15435309
Stock cooler "works" but it won't be pleasant.
Spend $20 on a generic tower cooler for better reaults
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1436638-i5-10400f-high-temps/#findComment-15435513
On 6/12/2022 at 4:16 PM, ezio313 said:
can the board lead to high temps?
sometimes
If the board doesn't have a proper cooling system for itself and a proper power delivery for the cpu you can lose a lot of performance
Take an I7 10700
Put it on a Gigabyte B460M DS3H
Cpu will run at 80c+ and you will lose performance, saw that happening
On the other hand
Take an I5 10600k and put it on a Gigabyte Z490 AORUS Ultra and you'll be able to OC it until you reach the silicon's limit (with proper cooling ofc)
"I fear not the man who has practiced 10,000 kicks once, but I fear the man who has practiced one kick 10,000 times." - Bruce Lee
https://linustechtips.com/topic/1436638-i5-10400f-high-temps/#findComment-15437171
+1
any of these in Europe :
https://geizhals.eu/?cmp=2290937&cmp=2697370&cmp=2697351&cmp=2742035&cmp=1139715&active=0
With the Raijintek Themis II being the best bang-for buck with 5 heatpipe + LGA1700 for the future out of the box.
And any of these in the US:
https://www.amazon.com/dp/B00JQ2YDCY
https://www.amazon.com/Antec-A50-SP-Cooler-Heatpipes-Cooling/dp/B08JTS91VG
https://pcpartpicker.com/product/x2JmP6/deepcool-gammaxx-400-v2-645-cfm-cpu-cooler-dp-mch4-gmx400v2-bl
https://www.amazon.com/dp/B09Q7XVZ2V
https://www.amazon.com/dp/B08JCG2V6P
With the ID-COOLING SE-214-XT being the best bang-for buck in the US.
https://linustechtips.com/topic/1436638-i5-10400f-high-temps/#findComment-15437245
