Yes, the 4pin is for extreme overclocking, 1x 8pin is fine.
But if you have a 750w psu, it should at least have 2x 8pin cpu cables, and those 8pin CPU cables are actually 2x4pin, so split one of those to get that 4pin.
I only see your reply if you @ me.
https://linustechtips.com/topic/1436632-new-build-help/#findComment-15434778
If you're running a 12900K(S), I would want the extra 4 pin plugged in, but the board will turn on with just the 8 pin plugged in, and the 8 pin can handle ~400W by current spec on the connector, so if you aren't gonna be near that 400W limit there isn't a reason you need the extra 4 pin.
It doesn't hurt to have it connected, but since that connector is hard to reach when you're in a case I wouldn't blame you for not bothering to plug it in.
https://linustechtips.com/topic/1436632-new-build-help/#findComment-15434853
