My PC has been in storage for a while, and I've just got it back.
I took it apart to make sure nothing was damage and that everything was seated correctly, and all seems fine. I replaced the thermal paste on my AIO, reassembled everything, and now my CPU immediately overheats to around 85-90°C, leading to an overheat error on POST.
As I said, I've reseated the AIO and replaced the thermal paste, as well as resetting the BIOS to default settings (except setting the CPU fan to ignore the RPM because it's running an AIO pump, which I can feel working when I put the back of my hand to the block) but that doesn't seem to have done anything.
My specs are:
i5-4690k
Corsair H100i GTX AIO cooler
16GB Corsair Vengeance DDR3
MSI GTX 1070 GAMING X
Corsair CS750M PSU
https://linustechtips.com/topic/1436145-i5-4690k-overheating/
You say the system was in storage for a long while - how long are we talking about?
Or rather, more to my point - how long has the AiO been unused? And how old is it, in general?
If I'm not mistaken, the liquid inside AiOs can go bad after several years, so it could be that yours is now past its prime. Can you try attaching a normal air cooler (even the shitty stock intel one would do for a test)?
https://linustechtips.com/topic/1436145-i5-4690k-overheating/#findComment-15430967
The cooler is about 5 years old (it was running fine, if a little toasty before I stored it in February), and it's been sat since mid February until today
https://linustechtips.com/topic/1436145-i5-4690k-overheating/#findComment-15430976
Do you hear any quiet gurgle from the CPU block? If it makes abnormally loud sound or not even any sound, that means the pump is straight up dead, new cooler.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1436145-i5-4690k-overheating/#findComment-15431001
I could hear a slight gurgle, but I figured that was down to the fact that it was my tech-illiterate dad stored it with the radiator below the block. I put it the right way up for around 2 hours before I fired it up to make sure there was no air bubbles, but it just sounded like air in the loop.
https://linustechtips.com/topic/1436145-i5-4690k-overheating/#findComment-15431008
Even with a not working pump, the CPU shouldn't shoot straight up to 90C on POST like that. The block itself has some thermal mass, so it should take some time for the temperature to ramp up rather than spike up.
So it's worth checking that you actually remounted the cooler correctly. Remove the CPU block and check the thermal compound spread. If that checks out, then you have a bad AIO.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1436145-i5-4690k-overheating/#findComment-15431051
