So when i use it on my steel series mouse matt it jumps everywhere and dosent work. same when i use it on a book. But when i use it on my wooden table it works perfectly fine. it started happening yesterday. i have installed the newest drivers. Any ideas? Thanks
i7-4770k,EVGA GTX 780, 16Gb Ram, Corsair H100i, Corsair 750D, Asus z87 Pro, 120Gb Samsung SSD, 3TB Western digital x2 and corsair rm1000
https://linustechtips.com/topic/143475-cyborg-rat-3-problem/
Problems with laser mouse I guess.
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
https://linustechtips.com/topic/143475-cyborg-rat-3-problem/#findComment-1915356
I would also say that it might be an issue with the laser.
Case: Corsair Vengeance C70 Gunmetal Black CPU: i7-4770k Cooler: Corsair H100i RAM: 8gb Corsair Vengeance Pro GPU: ASUS Direct CUII 770 MOBO: Asus Maximus VI Hero PSU: EVGA Supernova 1000 G2
https://linustechtips.com/topic/143475-cyborg-rat-3-problem/#findComment-1915383
So i will have to buy a new one then?
https://linustechtips.com/topic/143475-cyborg-rat-3-problem/#findComment-1915402
No, just a different mat.
https://linustechtips.com/topic/143475-cyborg-rat-3-problem/#findComment-1915422
Cyborg Rat's have always had an issue with the lasers. Changing the mat can help, but not in all cases.
My RAT 7, has issues sometimes and I fix it by making sure the laser area is clean, use qtip cotton swab, or a bit of really soft tissue.
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
https://linustechtips.com/topic/143475-cyborg-rat-3-problem/#findComment-1915622
i think a metal mousepad should solve this issue, since it works better on a smooth surface.
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/143475-cyborg-rat-3-problem/#findComment-1915629
I've also had this issue, with my MMO 7.
Keeping the laser area clean works for me also on my plain black mousemat.
CPU: 6700k GPU: Zotac RTX 2070 S RAM: 16GB 3200MHz  SSD: 2x1TB M.2  Case: DAN Case A4
https://linustechtips.com/topic/143475-cyborg-rat-3-problem/#findComment-1917046
Same lazer started to go buggy as hell. became really random so i brought a new mouse
Its all about those volumetric clouds
https://linustechtips.com/topic/143475-cyborg-rat-3-problem/#findComment-1918360
