Tried installing additional RAM and now DRAM LED is on and PC wont POST
Just wanted to post an update for the solution:
I ordered a CH341a programmer off of amazon. One important note is that the programmers available on amazon (black PCB) only output at 5v, and some may come with a 1.8v adapter, but my chip was 3.3v which wasn't ideal for either option. There are voltage configurable CH341a v1.6 programmers available on Aliexpress, but shipping would've taken too long for me, and I don't have soldering experience to perform a voltage fix (found online) myself so I took the risk using the standard 5v and everything worked out fine. That being said, I would highly recommend you either perform the fix, or purchase a configurable program.
Now for actually removing and programming the BIOS chip, this video does a great job describing the approach, but my process had a few extra steps that I wanted to share. I was very lucky in that my chip was socketed, so I was able to avoid the soldering and just had to be careful not to snap the IC's feet while removing it. The video's description provides links to the programmer's driver, as well as the ASProgrammer software I used to do the chip's reading/writing.
Next up, you want to make sure that the software has support for your specific chip (info found on the chip itself). I was concerned that I didn't see support for my exact IC, but a quick entry into https://datasheet4u.com/ revealed it had a matched datasheet for a chip that was actually supported. If ASProgrammer doesn't support yours, maybe try NeoProgrammer (mine was on one but not the other), and if it's on neither, you may be SOL but I'm not too sure. I did however see several ebay listings for various pre-programmed BIOS chips, so you may want to give that a shot at your own risk.
Now you'll need a copy of your BIOS, found on your mobo's website. You'll need your bios as a .bin file to program your chip, and unfortunately ASUS only provides them as .cap. There may be other solutions for this, but the one I landed on was found in this video where you basically just have to remove the first 800 bytes from the .cap file and save to .bin.
Lastly, just reprogram the chip with your new bios as shown in the video, making sure you verify the read/write processes worked as expected, and then finally pop the newly flashed chip back on your mobo and hopefully everything works. Your BIOS settings will of course be reset so you'll probably have to make a few changes. Hope this may help someone else who's ever in this predicament as even a PC repairman had told me my mobo was completely bricked and trying this fix saved me a lot of money. Thanks to everyone for the suggestions.
