Motherboard Optical Audio Port
An0maly_76
Go to solution Solved by Stormseeker9,
@An0maly_76
from the manufacturer website
“ Optical S/PDIF out port(s) at back panel“
Specifically on the Asus Tuf B550 PLUS. Is this an input or an output?
I have music equipment I need to be able to live monitor outside of recording, but also need to split between multiple outputs (already have that handled), and I think an SPID audio extractor combined with the Line In may do the trick.
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
@An0maly_76
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
