Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
I'm getting the Be Quiet Pure Base 500DX and I'd like to mount a 360mm radiator at the front. If I was to orient it pipes down, what AIO would come with pipes long enough to reach the cpu? And would I have any clearance issues? Apparently the HHD cage can be repositioned to allow for a 360mm radiator but would there also be enough space for the pipes at the bottom?
https://linustechtips.com/topic/1432838-suggestions-for-aio/
Country:
Just go for 240 or a 280 if that fits on roof. The whole point of mesh fronted cases is the improved airflow in and that goes away the second you block it with a radiator. Good 240 aio:s are better than some 360:s. Arctic Liquid Freezer II 240, Ek aio 240, Phanteks glacier one t30 240 and some others are good choices.
https://linustechtips.com/topic/1432838-suggestions-for-aio/#findComment-15407383
51 minutes ago, Jeppes said:
Just go for 240 or a 280 if that fits on roof. The whole of mesh fronted cases is the improved airflow in and that goes away the second you block it with a radiator. Good 240 aio:s are better than some 360:s. Arctic Liquid Freezer II 240, Ek aio 240, Phanteks glacier one t30 240 and some others are good choices.
Yeah this is pretty bang on, but I think the Pure Base 500DX can actually fit a 3 x 140mm rad in the front so you could get an Arctic Liquid Freezer II 420 if you had the budget. If you're cooling something like a 12600k though, it wouldn't be necessary. The Pure Base 500DX can fit rads with the tubes at the bottom, the only question then would be the if the tubing was long enough to reach the socket. The easiest solution would be to get a 240mm rad and then if it doesn't fit it could go in the top.
https://linustechtips.com/topic/1432838-suggestions-for-aio/#findComment-15407462
I have the Arctic Liquid Freezer II 280 and I'm very happy with it. It did surprise me on how thick it is. I recommend looking at all the dimension specs carefully.
https://linustechtips.com/topic/1432838-suggestions-for-aio/#findComment-15408195
13 hours ago, ts7n4gw said:
I'll be cooling a Ryzen 7 5800x
You could easily cool that with an air cooler such as the Scythe Fuma 2 or Deepcool AK620 etc.
Some liquid cooler reviews state the tube length. The Arctic Liquid Freezer II 360mm A-RGB for example has a tube length of 450mm according to the review below.
https://www.kitguru.net/components/cooling/luke-hill/arctic-liquid-freezer-ii-360-a-rgb-review/
https://linustechtips.com/topic/1432838-suggestions-for-aio/#findComment-15408587
