when watching video on second monitor, main monitor stutters
m0oble
so basically if i have a game on my main monitor, it will run at 144hz fine, but if i have a video, or anything moving on my second monitor, my game will stutter for as long as that thing is moving on the second monitor.
i have an rx 6600xt and i just installed the latest drivers
pc specs:
PCPartPicker Part List: https://pcpartpicker.com/list/CGMcL9
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($180.00)
CPU Cooler: be quiet! Pure Rock Slim 2 CPU Cooler  ($20.00)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  ($70.00)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($80.00)
Storage: Western Digital Blue SN570 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($90.00)
Storage: Western Digital Blue 6 TB 3.5" 5400 RPM Internal Hard Drive  ($110.00)
Video Card: PowerColor Hellhound Radeon RX 6600 XT 8 GB Video Card  ($400.00)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($99.99)
Power Supply: Cooler Master Silent Pro M 700 W 80+ Bronze Certified Fully Modular ATX Power Supply  ($100.00)
Total: $1229.99
bump
pc specs:
Total: $1229.99
I know this has been almost completely fixed on Nvidia, but I'm not sure of AMD.
Make sure you're running Windows 10, v1904 or newer, and latest GPU drivers.
After that, check the Windows display hardware scheduler.
For Windows 11 (and I think this also applies to 10), go to Settings, Display, Graphics.
Click the link that says "change default graphics settings" - it should be under a header that says Default Settings.
Here you'll find a toggle switch for "hardware-accelerated GPU scheduling." Make sure this is on; reboot your PC if you're just now enabling it.
If it already was enabled, then I think you're out of luck.
This scheduling problem was the sole reason I stopped using multiple displays on PC, especially with mixed refresh rates.
