Difference between ironwolf and the pro version?
Go to solution Solved by Eigenvektor,
4 minutes ago, manikyath said:
RPM, cache, and i'm assuming the PRO is also rated for a bunch more disks in a single enclosure.
Yep, further down the page you can see Bays: Up to 8 —vs— Up to 24 (Pro)
The pro also has a slightly higher Mean Time Before Failure (1.2M vs 1M hours MTBF), 4 year vs 3 year limited warranty and is rated for 300 TB/year instead of 180 TB/year.
https://www.vueville.com/home-security/cctv/nvr/ironwolf-vs-ironwolf-pro-nas-hard-drives-compared/
