42inch is considered small now. expect at least 55inch.
https://linustechtips.com/topic/1431163-42-qd-oled/#findComment-15396381
  • 4 weeks later...
Currently, 55", 65" and 34" ultrawide are the only QD-OLED sizes that can be bought from Samsung Display. It's currently unknown when or if other sizes will be available.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1431163-42-qd-oled/#findComment-15429552
On 5/14/2022 at 5:50 PM, Psittac said:
Crap, I just want it for a computer desk
Get a TV stand, move your desk back by 2-3' extra.
If you're fine 2' from a 27" display then you're fine 4' from a 55" display.
5900XT (16C/32T) | 64 GB DDR4 RAM | RTX 5070
1.5TB Optane P4800X | 16TB nvme SSD NAS w/ 10Gbe & 96GB DDR5 RAM caching
LG C4 + QN90A | Sony AZ7000ES | Polk R200+R100, ELAC OW4.2, SVS PB12-NSD + 3x SB1000 | HD800
https://linustechtips.com/topic/1431163-42-qd-oled/#findComment-15439545
