Budget (including currency): 1000 already have 3060
Country:
Games, programs or workloads that it will be used for: valorant tombraider cs doom
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): 144hz 1080p
my config to now is:i7 11700f,rgb rt 16gb 3200,msi h510i pro wifi,nzxtzth1(2022)kingston nv1 1tb
https://linustechtips.com/topic/1431079-mini-itx-build-help/
Are there parts you already have or parts you want to buy?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1431079-mini-itx-build-help/#findComment-15395778
13 minutes ago, byRelaxo said:
nah i like the h1 very
Make sure to use the quote button, or we will not see your responses
Have a look at this
PCPartPicker Part List: https://pcpartpicker.com/list/R7FTMb
CPU: Intel Core i7-12700F 2.1 GHz 12-Core Processor  ($312.95 @ Newegg
CPU Cooler: EVGA CLC 120 CL11 58.87 CFM Liquid CPU Cooler  ($77.09 @ Amazon)
Motherboard: ASRock B660M-ITX/ac Mini ITX LGA1700 Motherboard  ($119.99 @ Newegg)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  ($59.99 @ Newegg)
Storage: Crucial P2 2 TB M.2-2280 NVME Solid State Drive  ($156.99 @ Newegg)
Video Card: EVGA GeForce RTX 3060 12 GB XC GAMING Video Card  (Purchased For $0.00)
Case: Silverstone SG13 Mini ITX Tower Case  ($68.70 @ Amazon)
Power Supply: Corsair CXF 650 W 80+ Bronze Certified Fully Modular ATX Power Supply  ($73.40 @ Amazon)
Total: $869.1
Primary PC:
PSU tier list
https://linustechtips.com/topic/1431079-mini-itx-build-help/#findComment-15395797
CPU: Intel Core i7-12700F 2.1 GHz 12-Core Processor  ($312.95 @ Newegg)
CPU Cooler: Scythe Mugen 5 S 51.68 CFM CPU Cooler  ($56.99 @ Amazon)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($102.97 @ Amazon)
Storage: ADATA XPG SX8200 Pro 2 TB M.2-2280 NVME Solid State Drive  ($187.99 @ Best Buy)
Case: Cooler Master MasterBox NR200 Mini ITX Desktop Case  ($82.99 @ Newegg)
Power Supply: Cooler Master V SFX Gold 750 W 80+ Gold Certified Fully Modular SFX Power Supply  ($119.99 @ Amazon)
Total: $983.87
Generated by PCPartPicker 2022-05-14 11:35 EDT-0400
https://linustechtips.com/topic/1431079-mini-itx-build-help/#findComment-15395801
