Budget (including currency): Around 1700 euro's (1770 usd)
Country: Netherlands
Games, programs or workloads that it will be used for: It will be used for a wide variaty of game's and and some stuff for school.
Monitor: I currently own a 1080p monitor and plan on getting a second monitor in the future
This is my first pc build, upgrading from the prebuild pc i bought about 5 years ago. I kinda know what im doing but just to make sure i'd like to have some feedback on the parts i chose: https://nl.pcpartpicker.com/list/zvdC8r
https://linustechtips.com/topic/1431070-first-pc-build/
That's a lot of money for motherboard and CPU.
If you want to go for gaming, you could get a 12600, a B series motherboard and a better graphics card for 1440p gaming or keep the current graphics card and save some money.
And you can save some money by getting 3-packs of fans.
I mean sure, you can overclock the hell out of this CPU, but why?
It will not bottleneck a current graphics card for gaming anyway, so you throw out a lot of money for CPU performance, which you probably never really need.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
https://linustechtips.com/topic/1431070-first-pc-build/#findComment-15395712
Are you planning on overclocking the CPU? If not:
PCPartPicker Part List: https://nl.pcpartpicker.com/list/FPYJnt
CPU: Intel Core i7-12700F 2.1 GHz 12-Core Processor (€365.95 @ Megekko)
CPU Cooler: Enermax ETS-T50 AXE ARGB 71.32 CFM CPU Cooler (€54.90 @ Amazon Netherlands)
Motherboard: ASRock H670 Steel Legend ATX LGA1700 Motherboard (€183.85 @ Megekko)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (€89.00 @ Paradigit)
Storage: Crucial P2 2 TB M.2-2280 NVME Solid State Drive (€184.92 @ Amazon Netherlands)
Video Card: MSI GeForce RTX 3060 12 GB VENTUS 3X OC Video Card (€531.83 @ Amazon Netherlands)
Video Card: Sapphire Radeon RX 6700 XT 12 GB PULSE Video Card (€651.96 @ Amazon Netherlands)
Power Supply: Corsair TXM (2021) 750 W 80+ Gold Certified Semi-modular ATX Power Supply (€73.85 @ Megekko)
Case Fan: Cooler Master MasterFan MF Halo 47.2 CFM 120 mm Fan (€14.99 @ Amazon Netherlands)
Custom: DeepCool Matrexx 55 V3 ADD-RGB tower-behuizing (Wit, 2x USB-A 2.0, USB-A 3.2 (5 Gbit/s), 2x Audio, Window-kit, Outlet) (€53.91)
Total: €2250.13
Generated by PCPartPicker 2022-05-14 15:58 CEST+0200
You can save some money on the CPU and motherboard, and step up the graphics card. I also recommend a less expensive SSD for a gaming focused PC
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1431070-first-pc-build/#findComment-15395724
This seems like it'll be a nice build! A few things:
  • The fans seem really expensive---is that something you need? I see that the case you have doesn't have fans, but couldn't you instead buy something nicer like the p400a in white or something like that? I've used DeepCool Matrexx cases before in builds, and let's just say I'm not a fan.
  • I agree with the comments about the board---you should go for something lower-end, especially with your choice of ddr4 because you'll probably be inclined to upgrade that whole situation later on.
    • You'll probably also be able to go for a non-k SKU and experience essentially the same performance
    • If I were you, I'd look at your workload to determine whether you actually need a 12700 at all. You could probably save some more money now by going for a lower-end SKU and then buy a used, higher-end SKU a few years down the line for much less
  • The cooler also seems rather expensive for what it is, and does it not come with thermal paste? You can generally find Arctic mx-4 in larger quantities for really cheap if you really need to buy more thermal paste.
https://linustechtips.com/topic/1431070-first-pc-build/#findComment-15395735
  • I chose these fans because i wanted some nice white rgb fans to match my white/rgb theme for this build, same goes for the Matrexx as i just think its going to look very clean on my desk. This is also the reason i chose this cooler.
  • I added the termal paste because i honestly have no idea if it comes with the cooler or not so i figured i would rather be safe then sorry and just get some for those few euro's
  • On the cpu, im currently looking into maby getting a 12600 based on other comments
https://linustechtips.com/topic/1431070-first-pc-build/#findComment-15395742
Unless you're buying a used CPU cooler, you can expect a CPU cooler to come with thermal paste.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1431070-first-pc-build/#findComment-15395745
Total: €2250.13
Thanks, might take a look into some of these things. Already downgraded the motherboard to a Asus TUF GAMING B660-PLUS WIFI D4 ATX LGA1700 Motherboard as this also supports wifi. For the gpu im not sure yet, i think still going with a Geforce motherboard based on earlier experiences with it
https://linustechtips.com/topic/1431070-first-pc-build/#findComment-15395749
You might be able to find a 3060 ti for a reasonable price at a local shop, the PCPartPicker listings had their prices super high.
You might also consider a used RX 2080
Primary PC:
PSU tier list
https://linustechtips.com/topic/1431070-first-pc-build/#findComment-15395752
Would you recommend me to take a gpu with 8gb or 12gb based on the fact that im mainly using it for gaming?
https://linustechtips.com/topic/1431070-first-pc-build/#findComment-15395766
If you're not gaming at 4K, 8GB is going to be sufficient for your experience. But don't buy a GPU based on the ram, buy based on performance.
The 3060 ti is faster than a 3060 in gaming, even with less ram.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1431070-first-pc-build/#findComment-15395767
