well i my pc blue screened for the first time today and i dont know why any one know and how to fix it
spec's
asus sabertooth 990fx r2.0
amd fx8320
8gig corsair vengance ram
2 x evga gtx 660 ssc
500gb segate baracuda 7500rpm hdd
western digital 400gb hdd
any help would be nice thank's.
Problem signature:
  Problem Event Name:    BlueScreen
  OS Version:    6.1.7601.2.1.0.256.1
  Locale ID:    2057
Additional information about the problem:
  BCCode:    50
  BCP1:    FFFFFA800C609000
  BCP2:    0000000000000000
  BCP3:    FFFFF8800EFBF61E
  BCP4:    0000000000000000
  OS Version:    6_1_7601
  Service Pack:    1_0
  Product:    256_1
Files that help describe the problem:
  C:\Windows\Minidump\050813-30326-01.dmp
  C:\Users\james\AppData\Local\Temp\WER-52821-0.sysdata.xml
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
I did a thing once and it was awsome: https://soundcloud.com/jamese666/junkhead-cover-with-vocals
https://linustechtips.com/topic/14308-pc-bluescreen-and-dont-know-why-help/
I recommend reading through the trouble shooting page on the forum
http://linustechtips.com/main/forum/46-troubleshooting/
there are alot of fault finding tips already in there relating to BSOD
Its all about those volumetric clouds
The BCCode 50 usually occurs after the installation of faulty hardware or in the event of failure of installed hardware (usually related to defective RAM).
Try and run memory diagnostic test to check on memory failure.
Also try and update other drivers. (video cards, ect...)
Are your system overheating?
nah no overheating really its really cool it was idaling at 12c on the cpu and gpus where 20c and 25c when it happened
have you installed anything latly or updated anything?,
if not memtest sounds like the next step
apart from gpu drivers and antivirus no. i noticed though that my bio's set ram to 1333mhz and changed it to 1600mhz a while back dont know wether or not that could be the problem i get doin the mem test now and let you know what it says
set it back to 1333 and see if it BSOD
i set it back now and no problems so  far ill do some stress and see if bsod again and ill let you know :)
just stress tested the whole system and no problems so might be just a one off ill just wait and see if it bsod again or not thanks for the help guys
It may be the timings, also do a memtest just to be sure :D
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
