I want to exchange my xonar phoebus with a better external sound solution like the upcoming fiio e10k or the o2+odac (dont know what yet)
The only software feature i use from the phoebus is the volume leveler (makes it so the sound between applications doesnt differ as much)
Does anyone know of any good freeware or another way to get a volume lever with an external solution?
Thank you :)
https://linustechtips.com/topic/143028-volume-leveler/
cant windows do this?
you just click on the sound item in the task bar and click the mixer button, they you can choose how loud applications are in comparison with each other
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1909197
i think windows can do it, but i dont know if it still functions if you use the dac/amp
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1909219
Wouldn't matter what the amp can do I'd windows can do it, but before buying anything, make sure you headphones are up to par, and no M50's don't count
vmoda m100 and focal spirit professional.
So you think id be able to use windows volume leveler with the dac/amp?
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1909787
Iknow you would be able too.
Neither of those headphones are hard to driver, but you could do worse I do suppose. (by no means hating you headphone choice, just stating they don't really need an amp)
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1909927
you are right in this matter, but a good source can benefit them, i might just go with the e10k when it comes out.
Also sometimes an amp can really change the way a hp sounds, for good or bad. evn if its low impedance
also the 10 output impedance is actually bad for low impedance headphones.
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1910015
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1910041
Ever think to try them objectively off you onboard solution? (Asuming that you board was produced in the past fiveish years)
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1910077
By all means, just no what you are walking into I do suppose.
And the Xonar is a no go.
thanks for your help good sir, i will buy audio equipment even if i know the improvement is going to be marginal at best :D you do get a nice physical volume controller though :rolleyes:
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1910278
Not a problem, if you have any farther questions, feel free to ask. I, or one of the other regulars, will hop on it when we get the chance.
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1910352
you're awesome, and by the way i just did like a really short, not scientific. A/B test between my motherboard and my soundcard.. and if im absolutely honest, its difficult to tell a difference between them, and i think it would be the same with a new dac/amp..
I now know how much people on headfi can hype stuff up way out of proportions. ''my stx is sooo much better than an xonar phoebus'' bs i say.
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1910392
your awesome, and by the way i just did like a really short, not scientific. A/B test between my motherboard and my soundcard.. and if im absolutely honest, its difficult to tell a difference between them, and i think it would be the same with a new dac/amp..
Headfi is pretty much satan in my (And others) opinion. By no means needing to be scientific, its all about what you hear anyway, I'm just here to attempt to get you to some point or another. Like I said earlier though, as long as you know what you are getting into.
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1910417
may i know your setup by the way? you got me curious :)
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1910454
No a problem, presently using my Momentum On Ear off a release date iPhone 3G. At home I have my SRH1540's off either a E07k, O2, SA-150, or my X79-UP4. I also have 7506's, SE-215. Review samples range from both M50's to A forgettable pair of TDK's. I do plan on ditching my Blose system in my Miata for something with a legitimate low end. By that's after stage 2 and a new tranny.
Edit: Most of which are pictured on my profile.
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1910516
really nice, you should check out the focal spirit pros sometime, if you like the srh1540 http://www.innerfidelity.com/content/innerfidelitys-wall-fame-full-size-sealed just under the srh's :D
could you tell me, in pure honesty if you can tell the difference between the e07k and o2(with source?) sound quality wise?
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1911068
I have tried them, which is why I went 1540.
Isn't really any difference, one has eq options and the other doesn't.
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1911617
hmm interesting.. how people are like ''but this sound is so much clearer'' and im like, my sound is crystal clear as is.. what more do you want.
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1911628
Human mind is an interesting thing that works in interesting ways. But what you are describing is placebo, which is the human mind attempting to justify an action. In this case a purchase of one product over a different one. Like Intel/AMD wars, Ford/Chevy, Mustard/Mayonnaise. You feel?
https://linustechtips.com/topic/143028-volume-leveler/#findComment-1911858
