Hello.
I cant find a way to get the text inside a sentence in python. This is the code
import re
f=open("weather.txt", mode="r", encoding="utf8")
content=f.read()
f.close()
pattern=re.compile("[0-9]") # TO BE CHANGED!
result=pattern.findall(content)
print(result)
print(len(result))
I cant get the proper command for re.compile. For eg. I need to get the program to tell me the items inside the ( ).
https://linustechtips.com/topic/1430008-python-regex-issue/
So in weather.txt you have numbers within () that you want to match ie (123)
Regex would be
\([0-9]+\)
The backslash is used to mean match literal () as they have special meaning in regex.
https://linustechtips.com/topic/1430008-python-regex-issue/#findComment-15388399
3 minutes ago, C2dan88 said:
The regex becomes a bit more complex
\(([0-9]+(\.[0-9]+)?) C\)
This interactive website will help to explain it
https://regex101.com/r/vI6O1w/1
for eg  the items inside (-1.7 C) will be output as ('0.7', '.7'), There is something with the decimals.I will look into the link in the meanwhile
https://linustechtips.com/topic/1430008-python-regex-issue/#findComment-15388411
\((-?[0-9]+(?:\.[0-9]+)?) C\)
Use above pattern to include negatives. With this you should get only 1 output. Don't forget these are strings, you'll need to parse them into double (use "float(x)")
If you found my answer to your post helpful, be sure to react or mark it as solution 😄
https://linustechtips.com/topic/1430008-python-regex-issue/#findComment-15388418
4 minutes ago, FreQUENCY said:
@C2dan88 Works but i need to tweak it to get the C too. The result is
['-1.7', '0.7', '1.4', '1.5', '1.7', '1.9', '24.3', '24.2', '23.8', '23.3', '23.1', '22.8', '22.7', '22.6']
14
Is your way the "correct" way or is it a workaround for this case?
Then simply extend the capture group to include the 'C'
Quote
\(([+-]?[0-9]+(?:\.[0-9]+)? C)\)
https://linustechtips.com/topic/1430008-python-regex-issue/#findComment-15388429
Works like a charm.I picked a course that teaches regex too and i am so lost.
I need to figure out how to:
  • get the word that is previous of the date
  • find the words that start with a Capitalised letter and have at least 3 characters in length.
@JogerJCan you please explain me in english how this is formed? So i can understand it ?
Quote
https://linustechtips.com/topic/1430008-python-regex-issue/#findComment-15388438
Well I don't like doing other people's homework but this should provide a clearer breakdown https://regexr.com/6l8cg
You should at least familiarize yourself with the cheatsheet so you know what you can do with regex, then work your way with it.
I'll provide some hints:
  • Getting word previous of date:
    Pattern for the word belongs in first capture group, then follows a non-capturing group with the date
  • Capitalised 3+ char words:
    First letter is uppercase, then followed by at 2 or more lowercase letters (or also uppercase or even numbers, depending on definition of "word")
Give a shot at it and I'll help correct mistakes you might make
https://linustechtips.com/topic/1430008-python-regex-issue/#findComment-15388757
  • 1 month later...
I just want to drop this here.
When learning regular expressions, please, please, please read about "greediness", particular in relation to .* and please, please, please learn to "anchor" your regexps.  This is by far the most common problem with regular expressions in the wild.
Example:
Make sure this is our domain:    .*.ourdomain.com
Nope.  That's not what that does.  If fact.  These match it.
www.yourdomain.com
lets-hack.ourdomain.com.xackorspz.org
Make sure this is our domain:    ourdomain\.com$
Better.  The .* is pointless and the $ forces this now to match only strings which end with the literal ourdomain.com.  It's also simplier.
I would recommend, taking any code which uses a regular expression, pulling the regexp bit out into a method and unit testing the sh1t out of it.  Give it a list of things, positive and negative tests.  Send it round the team and make it a challenge.  Can you break it?
https://linustechtips.com/topic/1430008-python-regex-issue/#findComment-15439356
