I just saw Linus's video on the R9 295X2, and he said something that caught my attention;
he mentioned that the PCI-e connectors had to be set up in a specific way, not using the chained cables.
So...unless otherwise stated, is it even OK to assume that GPUs requiring two 6-pins/6-pin & 8-pin/two 8-pins can use one connector per card?
I have a Corsair AX850, and it ultimately has 4x 6+2 pins. Without much doubt, I'm sure this PSU can handle two mid-range or mid-high GPUs in SLI/CrossfireX.
However, I don't think this PSU could handle high-end, power-hungry cards in SLI/CrossfireX.
Is this issue of PCI-e cable splitting something to be worried about?
https://linustechtips.com/topic/142941-psu-pci-e-connectors-split/
i think what you mean is you only use on of the connectors per card, i dont think you can use only one of the pci power and you can cf/sli any single gpu card on that psu
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
Most cables have two 8 pins on one cable it is recommended to use 2 seperate cables.
i have two 8pins off one 8pin
My Setup :P
If you have a good like real good high quality psu you should be fine but this card can pull lot's of amps on a single rail.
oh got ya i have a r9 280x on a antec 80+bronze 850w xD
My Setup :P
Yeah you should be fine I ran a oced 7970 on a crappy non certified 450w psu for 1,5 year with no problems.
my god my old psu couldent handle this card on bf4 low settings
My Setup :P
