3090 Memory not cooling down.
Go to solution Solved by NextraMia,
i forced the fan curve to always have the fans spinning, now my pc is going down in temps 🙂
Hello!
I've had my Gigabyte 3090 for a while now and never really had any problems with it before except for just now. I was just casually playing csgo when i heard my fans go up to max so i was wondering what was happening, that's where i saw that my gpu memomry reached nearly 105 degrees. Not long after i saw that issue my pc died from possibly over heating...
I've restarted it a few times and had it idle with side panel open and even windows open, yet my gpu memory doesn't cool down from 70 degrees idle. Like i said, i've not had this issue before as i even played yesterday with no such problems, neither have i downloaded anything new on my pc.
What could be the possible problems? Since i've never had this problem before...
CPU: AMD Ryzen 9 5950X ||| GPU: Gigabyte GeForce RTX 3090 GAMING OC ||| Motherboard: Asus Rog Crosshair VIII Dark Hero ||RAM: G.Skill Trident Z DDR-4400 CL16 ||| PSU: Corsair HX Platinum 1200 W 80+ ||| Case: Lian Li - O11 Dynamic Evo ||| Storage: 2x Samsung 980 Pro 2 TB NVME SSD ||| Cooling: (CPU: EKWB RGB 360 AIO) (Case-Fans: Lian Li SL-120 Infinity)
https://linustechtips.com/topic/1428535-3090-memory-not-cooling-down/
i also see that the backplate is super hot yet my fans are not spinning...
