Hello, I have a problem with Gigabyte z370 aorus gaming k3[With latest bios version F15], my bios settings won't apply.To be more exactly the Intel EIST function is turned off in bios but always when i boot in windows and open Hwinfo64 the EIST function seems to be enabled. I tried the optimised defaults, changing bios battery, disable just the EIST to see if it still appears on in windows,changing power plans[from high performance,ultimate performance,bitsum,quick cpu]... I don't really know what can i do.
Specs: Intel core i5 8600k 5GHZ 1.368V LLC: Turbo
Gigabyte Z370 aorus gaming k3
Corsair 16gb 3600 cl16
Sirtec High power element smart 650W 80+ bronze
 Arctic Liquid Freezer 420mm.
https://linustechtips.com/topic/1427745-motherboard-problem/
Try clear CMOS and redo all your settings
Desktop benching:
https://linustechtips.com/topic/1427745-motherboard-problem/#findComment-15372612
Right now i did this but nothing changed... In hwinfo64 JUST THE EIST REMAIN ON.Always when i boot in windows i need to open QuickCpu to uncheck the EIST and the PROCHOT, and when i reopen HWinfo64 the EIST changed OFF[in bios all c-states,sst,eist,etc are OFF] I literally want to smash this mobo... I promise to myself that i will never ever buy gigabyte anymore.
https://linustechtips.com/topic/1427745-motherboard-problem/#findComment-15372654
