Hello everyone.
I'm currently looking at parts which I want to use in a PC i'm going to build and as i'm going to spend quite some money I want to do it right the first time.
I'm looking at the 600-750 watt range and wish to spend about up to 70 euros or so.
I live in The Netherlands so the price is in euros.
I myself looked at the Seasonic M12II 620W PSU, the Cooler Master GM 650W and the Cooler Master GM 750W but I can't really find any good reviews on the Cooler Master ones.
It doesn't have to be silent but I would like it to be modulair.
Any suggestions or tips are welcome.
Thanks in advance.
https://linustechtips.com/topic/142767-help-with-psu/
The Seasonic M12II Bronze 630w offers better cap choices, while the Cooler Master G650/750M will perform electrically better due to is DC-DC secondary, whereas the Seasonic is group-regulated.
Can you provide a link to where you are able to buy from, so we know what is available to you?
https://linustechtips.com/topic/142767-help-with-psu/#findComment-1905904
Whats your build?
As long as you don't have a GTX780TI and FX9590 you should be okay with a 550-600w PSU...
EVGA GTX760 Superclocked (ACX) - i5 4570 - 8GB DDR3 - 1TB Western Digital Caviar Blue - Corsair CX500 - NZXT Source 210(Black)  - 1x 120mm - Valley Bench http://imgur.com/J4EJnvV
https://linustechtips.com/topic/142767-help-with-psu/#findComment-1906610
Planning on getting the R9 290 and a I5-4670K.
And I can buy most stuff from either http://www.sicomputers.nl/ and or http://azerty.nl/
Wow Such Doge quan289
Shd0w2
Oh, sorry, I forgot to asked, but what is your budget as well? Edit: NVM, you had listed it. lol
Do you have any sort of plans on crossfiring?
https://linustechtips.com/topic/142767-help-with-psu/#findComment-1908109
Shd0w2
I would go with the XFX XTR 550w http://www.sicomputers.nl/componenten/videokaarten/ati/xfx/xfx-xtr-550w.html because it is made by Seasonic and 550w will be more than enough to power your system.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/142767-help-with-psu/#findComment-1937630
None @quan289
Ah, sorry. I had thought I replied to this. But yes, I agree with this recommendation by mgsstar.
It's a solid Seasonic unit that's based on the G series platform internally, but with a better FDB fan, full modularity, and a switch for semi-passive mode.
https://linustechtips.com/topic/142767-help-with-psu/#findComment-1937743
