I did my research, this is what I added to my cart. I am posting this because I do not want to buy something I do not need
Go crazy
I will use it for gaming
Games I will play
Sea of theives
Mincraft (With Shaders)
Fortnite
Star Wars the old republic
Forza Horizon 5
corsair-icue-7000x-rgb-full-tower-case-black-300px-v1.jpg&width=120&height=80 Corsair iCUE 7000X RGB Tempered Glass Full-Tower ATX PC Case - Black / Tempered Glass Side Panel / USB 3.1 Type-C port / Corsair rapid route cable management / Supports up to 480mm Radiator / CC-9011226-WW
corsair-dominator-platinum-rgb-32gb-ddr5-5600mhz-black-300px-v1.jpg&width=120&height=80 Corsair Dominator Platinum RGB 32GB (2x16GB) DDR5 5600MHz C36 Desktop Memory - Black / Speed Rating PC5-44800 / Onboard Voltage Regilation / Intel® XMP 3.0 Support / 12 Ultra-Bright Capellix RGB LEDS / CMT32GX5M2X5600C36
asus-rog-strix-650w-power-supply-300px-v1.jpg&width=120&height=80 ASUS ROG Strix 650G 650W Gold Power Supply / Dual ball fan / 80 Plus Gold Certification / Cosmetic customization / Fully modular cable / 0dB Technology / ROG-STRIX-650G
corsair-icue-h170i-elite-capellix-liquid-cpu-cooler-300px-v1.jpg&width=120&height=80 CORSAIR iCUE H170i ELITE CAPELLIX Liquid CPU Cooler / 420mm Radiator / ML140 RGB PWM Fans / Zero RPM Cooling Profiles / Magnetic Levitation Fans / CW-9060055-WW
intel-core-i7-12700f-processor-300px-v1.jpg&width=120&height=80 Intel 12th Gen Core i7-12700F up to 4.90 GHz Unlocked 25MB Cache LGA 1700 180W Desktop Processor / Turbo Boost Max Technology 3.0 / High-Performance Overclocking / Compatible With 600 Series Chipset / BX8071512700F
asus-rog-strix-b660-f-gaming-wifi-intel-motherboard-300px-v1.jpg&width=120&height=80 ASUS ROG STRIX B660-F GAMING WIFI ATX Intel Motherboard / Intel B660 Chipset / Supports 12th Gen Processors / LGA 1700 / Supports DDR5 Memory / Wi-Fi 6E Wireless LAN / 8x USB Type-A / 2x USB Type-C / 1x HDMI / 1x DisplayPort / 90MB18R0-M0EAY0
msi-geforce-rtx-3080-suprim-x-12gb-gddr6x-lhr-300px-v1.jpg&width=120&height=80 MSI GeForce RTX 3080 SUPRIM X 12GB GDDR6X LHR Graphics Card / 8960 Cuda Cores / Boost: 1905 MHz / Triple Fan / Precision-crafted Heat Pipes / 3x DisplayPort / 1x HDMI 2.1 / RGB Mystic Light / 912-V389-408
corsair-force-mp600-core-4tb-pcie-gen-4-m2-nvme-ssd-300px-v1.jpg&width=120&height=80 Corsair Force Series MP600 Core 4TB PCIe Gen 4.0 M.2 NVMe SSD / Maximum Read Speed 4,950 MB/s / Maximum Write Speed 3,950 MB/s / Lower Temperatures, Higher Performance / CSSD-F4000GBMP600COR
https://linustechtips.com/topic/1426725-first-pc-build/
Drop the over-priced aio and case. 4000D airflow(add two intake fans) or Lian Li 215 with Deepcool ak620 for example are smart choices and you save enough to upgrade the gpu to 3080ti. 4tb ssd:s usually a bit pricey. Get sn850/980pro 2tb and something like evo970plus/sx8200/cs3030 2tb for cheaper.
And you should go for 850W psu. Corsair rm and rmx usually good choices.
https://linustechtips.com/topic/1426725-first-pc-build/#findComment-15365268
Ok I will do that
https://linustechtips.com/topic/1426725-first-pc-build/#findComment-15365271
But the 3080 is 1905MHZ
And the 3080 TI is 1700MHZ
https://linustechtips.com/topic/1426725-first-pc-build/#findComment-15365274
Bassed on all your info I updated my wishlist
And I may also use it for video editing
orsair-icue-4000x-rgb-gaming-case-black-300px-v2.jpg&width=120&height=80
CORSAIR iCUE 4000X RGB Tempered Glass Mid-Tower Case - Black / RapidRoute Cable Management / Three Included 120mm RGB Fans / Fits up to 6x 120mm or 4x 140mm Cooling Fans / Fits up to 2x SSDs and 2x HDDs / Modern Front Panel I/O / CC-9011204-WWRead More...
corsair-mp600-pro-2tb-pcie-gen-4-x4-ssd-300px-v1.jpg&width=120&height=80 Corsair MP600 Pro 2TB PCIe x4 Gen M.2 NVMe SSD / Maximum Read Speed 7,000 MB/s / Maximum Write Speed 6,550 MB/s / Lower Temperatures, Higher Performance / CSSD-F2000GBMP600PRORead More...
msi-geforce-rtx-3080-ti-ventus-3x-12gb-oc-gddr6x-300px-v1.jpg&width=120&height=80 MSI GeForce RTX 3080 Ti VENTUS 3X 12GB OC GDDR6X Graphics Card / 10240 Cuda Cores / Boost Clock: 1695MHz / 384-bit Memory Bus / 3x DisplayPort / 1x HDMI 1 / 912-V389-059Read More...
corsair-tm30-thermal-paste-300px-v1.jpg&width=120&height=80 CORSAIR TM30 Performance Thermal Paste / GPU Thermal Compound / Enthusiast CPU Thermal Compound / Improved CPU Cooling / Installation Made Easy / Reliable and Safe / Long Service Life / CT-9010001-WWRead More...
corsair-dominator-platinum-rgb-32gb-ddr5-5600mhz-black-300px-v1.jpg&width=120&height=80 Corsair Dominator Platinum RGB 32GB (2x16GB) DDR5 5600MHz C36 Desktop Memory - Black / Speed Rating PC5-44800 / Onboard Voltage Regilation / Intel® XMP 3.0 Support / 12 Ultra-Bright Capellix RGB LEDS / CMT32GX5M2X5600C36Read More...
corsair-icue-h170i-elite-capellix-liquid-cpu-cooler-300px-v1.jpg&width=120&height=80 CORSAIR iCUE H170i ELITE CAPELLIX Liquid CPU Cooler / 420mm Radiator / ML140 RGB PWM Fans / Zero RPM Cooling Profiles / Magnetic Levitation Fans / CW-9060055-WWRead More...
intel-core-i7-12700f-processor-300px-v1.jpg&width=120&height=80 Intel 12th Gen Core i7-12700F up to 4.90 GHz Unlocked 25MB Cache LGA 1700 180W Desktop Processor / Turbo Boost Max Technology 3.0 / High-Performance Overclocking / Compatible With 600 Series Chipset / BX8071512700FRead More...
ASUS ROG STRIX B660-F GAMING WIFI ATX Intel Motherboard / Intel B660 Chipset / Supports 12th Gen Processors / LGA 1700 / Supports DDR5 Memory / Wi-Fi 6E Wireless LAN / 8x USB Type-A / 2x USB Type-C / 1x HDMI / 1x DisplayPort / 90MB18R0-M0EAY0Read More...
NZXT C Series C850 850W ATX Power Supply / Hybrid Silent Fan Control / Fluid Dynamic Bearings / Modular Design / Sleeved Cables / 80+ Gold Certified / NP-C850MRead More...
https://linustechtips.com/topic/1426725-first-pc-build/#findComment-15365285
Go crazy
Games I will play
Sea of theives
Fortnite
Forza Horizon 5
get a stronger psu 650w isnt going to hold on so well, get a 850w psu ( dirrect recommendation is rm850x from corsair )
and a pretty overkill pc for your needs
https://linustechtips.com/topic/1426725-first-pc-build/#findComment-15365287
15 minutes ago, Duxa said:
can we get thw final result? really want to see it
corsair-7000d-airflow-full-tower-atx-pc-case-black-300px-v1.jpg&width=120&height=80 Corsair 7000D AIRFLOW Full-Tower ATX PC Case - Black / Tempered Glass Side Panel / USB 3.1 Type-C port / Corsair rapid route cable management / Supports up to 480mm Radiator / CC-9011218-WWRead More...
nzxt-c-series-c850-850w-atx-power-supply-300px-v2.jpg&width=120&height=80 NZXT C Series C850 850W ATX Power Supply / Hybrid Silent Fan Control / Fluid Dynamic Bearings / Modular Design / Sleeved Cables / 80+ Gold Certified / NP-C850MRead More...
There you go
https://linustechtips.com/topic/1426725-first-pc-build/#findComment-15365304
