would you be able to attach a screenshot of one of the non functioning sites?
Could you please list your system specs? If its a laptop the name would be nice.
Some general questions.
Do you have slow internet?
What browser are you using?
does your browser have javascript disabled?
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
To hijack what @SignatureSigneralso said. That general of a question would require more information to resolve. Try to explain the path you took to reproduce it and if it is only in some situations. There are numerous points on which a page not loading could fail.
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
59 minutes ago, Marcpc said:
Is there any solution to this
Probably. But your description is too vague to pinpoint an exact cause.
  • Could be caused by JavaScript being disabled > Check browser settings
  • Could be caused by a browser plugin (or browser itself) > Try again using incognito mode with plugins disabled and/or another browser
  • Could be caused by certain types of personal security software > Try again with these disabled
  • Could be caused by using a misconfigured proxy > Try again with a direct connection, if possible
  • Could be caused by malware > Run a check
  • Are you in a country that filters the internet? > (Could try using a VPN if it doesn't get you into legal trouble)
Does it only affect sites using HTTP or does it also affect sites using HTTPS? You could try with a Linux Live-USB image on the same PC, to verify whether it is restricted to Windows or affects any OS. Does it affect e.g. your phone when on the same network?
