Hey, everyone. With the recent death of my laptop occurring as I was going to upgrade consoles, I've decided it's more economically sensible to build a PC that can play games rather than buy a new laptop and a next/current/whatever-the-hell generation console. I think I've done alright so far, but having never done this before, I don't suppose I have much to lose asking people with experience. If it helps, I'll be using it primarily for web browsing, and games. I already have a monitor and more audio equipment then I have any right to own.
http://pcpartpicker.com/user/Slips_Perfidy/saved/4pT7
Here's the build I've compiled so far. I believe everything is compatible. What are the short-comings of the build (if nothing is incompatible)? If I were going to SLI another 760 later down the line, what would I need to change now?
I'm curious if I should get the FX-6300 as opposed to the 4300. I was under the impression that fewer cores, in general, were better for gaming, as there aren't any games really optimized to take advantage of the higher number of cores.
Thanks for any help, guys.
https://linustechtips.com/topic/142588-help-on-a-new-build/
You didn't pick a motherboard...
Heaven's Society - Like Anime? Check us Out Here!
https://linustechtips.com/topic/142588-help-on-a-new-build/#findComment-1903164
AMD has more cores but their cores are not as powerfull as intel's cores, and thus i would def go with a 6300 as the 4300 is really underpowered
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/142588-help-on-a-new-build/#findComment-1903165
An FX 4300 is fine for now, but will be a problem in the future as games such as Watch Dogs and BF4 do take advantage of AMD's 6 and 8 Cores. Eventually, Intel will also come on board with 6 and 8 core CPUs, and most games will use 6 and 8 Cores. For the sake of future-proofing, spend the extra $10 and get the FX 6300.
PC Build
AMD FX 4130@3.8GHz | Sapphire Radeon HD R9 290@947 MHz | 8GB of DDR3 1333MHz RAM | 500GB Seagate HDD | [broken] Cooler Master i600 PSU | Some LG Disk Drive that costed me $20|
https://linustechtips.com/topic/142588-help-on-a-new-build/#findComment-1903167
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($179.99 @ Micro Center)
Motherboard:  ASRock Z87 Extreme3 ATX LGA1150 Motherboard  ($109.99 @ Newegg)
Video Card:  EVGA GeForce GTX 770 2GB Video Card  ($339.99 @ NCIX US)
Case:  Antec One ATX Mid Tower Case  ($34.99 @ NCIX US)
Power Supply:  Raidmax 700W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($63.99 @ SuperBiiz)
Optical Drive:  LG GH24NSB0 DVD/CD Writer  ($15.98 @ OutletPC)
Total: $892.89
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-04-21 10:20 EDT-0400)
Get a friend with windows os oem to install it for you, get a cheap 10$ mouse from target or walmart.
Your previous build couldn't SLI because
A you didnt choose a mobo period -_-
b your wattage on your psu was too low.
Generally SLI and OC takes around 650 watts.
While this build doesn't have an SSD you can buy a better mouse and SSD down the road as your first upgrade
Then SLI and add in two more sticks of 4gb memory.
https://linustechtips.com/topic/142588-help-on-a-new-build/#findComment-1903185
Damn, you guys are quick! Thanks.
Total: $892.89
I actually posted the wrong link.
http://pcpartpicker.com/user/Slips_Perfidy/saved/4r76
Same components, but it contained a mobo. I rather like the build you've compiled, though. My friend, competitive CS player, swears by the Adder though. SSD was the plan for later down the line.
https://linustechtips.com/topic/142588-help-on-a-new-build/#findComment-1903260
I'm sure plenty of "pros" swear by different equipment. It comes down to what feels right in YOUR hand.
I'm not saying DON'T get the mouse, i'm saying way to get it till later.
https://linustechtips.com/topic/142588-help-on-a-new-build/#findComment-1903306
That seems conventionally wise enough for me. Thanks, I think I'll elect to go with your build, or at least use your build as a foundation for mine.
https://linustechtips.com/topic/142588-help-on-a-new-build/#findComment-1903329
Total: $892.89
I like most of this build, however I would get the 1tb WD Blue. It's like $5 more for double the space.
The optical drive is borderline useless.
I'd also cheap out on the mouse and get a solid SSD. It's a much, much bigger pain in the ass to replace an HDD with an SSD, swapping your OS etc than it is to simply unplug a mouse.
Avoid that power supply and get something of quality. It's the heart of your computer, and realistically should be one of the higher investment areas.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/142588-help-on-a-new-build/#findComment-1903341
I understand it is only slightly more expensive to get a 1TB HDD, but I could damn near fit every file I have on a 120 gig SSD. It just doesn't seem practical to invest in space that I doubt I'd ever use.
I'll ditch the mouse for now, but I'm not sure if I can include an SSD. My budget is around 850-950$.
What PSU do you recommend? This is one area I'm totally clueless in.
Thanks, bud.
https://linustechtips.com/topic/142588-help-on-a-new-build/#findComment-1903375
Just make sure you match up the wattage of your PSU and your Mobo features with your plans for the future
You need to make sure your Mobo supports the CPU RaM and SLI .
Your PSU needs to have a little headroom for SLI Config (around 700ws+) is fine.
Psu get a semi-modular bronze silver gold or platinum as well as 700w+
the one i picked is a good choice
https://linustechtips.com/topic/142588-help-on-a-new-build/#findComment-1903384
Thanks, bud.
Then I'd get an SSD for now, and get an HDD later if you need.
120gb SSD's are only about $80. Samsung Evo is the one I'd go with.
If you play a lot of games think of it this way; newer games are going to take more space. Figure 50+ GB per title. It adds up quickly.
Do you download movies or music at all? They rapidly add up too. I never thought I'd fill my 2tb external, but it's already getting pretty close.
I'd go with a brand like Corsair (excellent warranty and support), EVGA (same as Corsair) or Seasonic.
There are of course other brands, and some of their PSU's are great, but generally everything from these guys is solid.
I'd recommend reading reviews before purchasing something. Don't blindly trust what you read on a forum. It's a great place to get ideas, but doing your own research as well will pay off in the end.
This site's a great way to figure out how much power you should try and get.
http://www.extreme.outervision.com/psucalculatorlite.jsp
I usually go one or two steps above their recommendation.
You can usually find sales on PSU's. I just picked up a replacement one for 60% off from NCIX.
While your recommendations are correct, the power supply you picked is garbage. Raidmax is one of the worst brands when it comes to PSU's. They should be avoided at all costs.
https://linustechtips.com/topic/142588-help-on-a-new-build/#findComment-1903471
Theres tons of people who've purchased this an were happy with thr results. While its not the worlds best psu it certainly isnt bad for the price. You'd pay an extra 20-30 for a great quality 700watt. (I will go double check for his sake but im on my phone so it might take a little)
https://linustechtips.com/topic/142588-help-on-a-new-build/#findComment-1903723
It has a pretty low rating on PCPP, and in general the brand is garbage.
A quality Corsair or Seasonic unit is only $40 more. An EVGA can be had for a mere $15 more.
When buying a power supply you should get a quality unit. A bad PSU can take other items with it when it dies. It's also a royal PITA to replace all the cables.
https://linustechtips.com/topic/142588-help-on-a-new-build/#findComment-1903817
I picked the wrong psu im sorry. Im on my phone so its a little hard. Theres one that's cheaper that's better.http://pcpartpicker.com/part/rosewill-power-supply-hive750
https://linustechtips.com/topic/142588-help-on-a-new-build/#findComment-1903938
So far, all that I've done is nix the optical drive, drop the GPU to a 760 and add your newly recommended PSU, which most reviews regard quite highly. I still haven't decided whether or not go SSD out of the gate or later, but I'll come to it.
No worries about the phone, man. You guys have helped a ton.
https://linustechtips.com/topic/142588-help-on-a-new-build/#findComment-1904815
Id recommend 770 EVGA its the best p2p and quality
https://linustechtips.com/topic/142588-help-on-a-new-build/#findComment-1906415
