What USB hub do you have?
If it's a hub with type c ports, are you sure those ports support data transfer too or are just to provide power?
NZXT S340 | Ryzen 7 5900X | B550 AORUS PRO V2 | TridentZ RGB 2x8GB 3200 | RTX 4070
Nintendo Switch (2x), Nintendo *New* 3DS, PSP-1000, PSP-2000 (Crisis Core Limited Edition)
MacBook Pro 14 (2021), 16GB RAM, 512GB ROM
https://linustechtips.com/topic/1425846-usb-hub-doesnt-work/#findComment-15359088
Its VOLK ML-CB26
Its USB 2.0 and its not a type c (my computer is too old for that lol)
the card reader and usb ports was working before but it doesnt work anymore I really dont know.
https://linustechtips.com/topic/1425846-usb-hub-doesnt-work/#findComment-15359093
Sounds like a damaged USB port in the USB Hub then.
https://linustechtips.com/topic/1425846-usb-hub-doesnt-work/#findComment-15359240
19 minutes ago, t0int said:
No, i said that when i plug my phone to the usb port it charges.
It charges, but do you also get data transfer on the phone?
If it just charges, it's not a functioning USB port.
https://linustechtips.com/topic/1425846-usb-hub-doesnt-work/#findComment-15359762
