3 minutes ago, Duxa said:
im from serbia, going for a full white build, dont tell me how components are overpriced cuz these are the best price i could find
BUILD
You can get a 5900x and a better board easy by cutting the aesthetics but if you prefer aesthetics over performance then you do you i guess
And bloody hell if you want a show build then fork up the money, even with all that rgb you arent gonna impress ppl if you still got a mediocre board, though if you are doing this just to make it look good and not impress ppl then board is a non issue
https://linustechtips.com/topic/1425584-thoughts-on-build-plan/#findComment-15357178
i want to go with aesthetics performance is just fine
changed it, better now?
https://linustechtips.com/topic/1425584-thoughts-on-build-plan/#findComment-15357201
I hope that Asus graphics card is actually available to you, I had a very hard time finding white graphics cards in general and they sell out fast. The price looks decent, at least in this current crappy market.
The Asus motherboard is a good call, my girlfriend's all white PC uses the Asus prime X570-P, and it looks pretty similar to the X570-Pro. The darker grey parts of the motherboard are outshined by the white accents and the LEDs of the fans will help the darker parts of the system look better.
The power supply is also a good choice, Corsair's white cables are very clean looking.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1425584-thoughts-on-build-plan/#findComment-15357205
Funny enough from where im buying people are selling 3060,3060 ti zotac white, and 3070,3080 and 3090 white strix gpus
Cheapest 3070 is 830€, 3080 is about 1200€ and i think 3090 is above 2000€
https://linustechtips.com/topic/1425584-thoughts-on-build-plan/#findComment-15357299
I think you are making the right choice by choosing the 3070 out of this group
Primary PC:
PSU tier list
https://linustechtips.com/topic/1425584-thoughts-on-build-plan/#findComment-15357391
