Can you transfer wifi between two pc's using ethernet.
Solved by kirashi,
12 minutes ago, SircarrotII said:If I have one pc with a wireless adapter and I hook that pc to another that doesn't have wireless networking with an ethernet cable from the motherboard ethernet port on both pc's. Will they be able to run off of the same wifi card?
Should be able to do this by enabling Windows Internet Connection Sharing (ICS) on the PC receiving its internet connection over WiFi.
https://www.majorgeeks.com/content/page/enable_disable_internet_connection_sharing.html
