Budget (including currency): 900 EUR
Games, programs or workloads that it will be used for: Games and maybe some video editing
Country:  Latvia
Other details:
I made a build and trying to find out if everything will work together and maybe some better options.
https://de.pcpartpicker.com/list/F9p4d9
I will try to buy it next month and want to get BenQ Zowie XL2540K, 24.5" 240hz monitor (monitor price not in the budget)
Thanks in advance.
https://linustechtips.com/topic/1423638-building-my-first-pc/
Get an SSD and get rid of the HDD
Upgrade the GPU to an RX 6600
Get a case that actually has airflow
If you do that you should get a great pc. Since you posted a Germany pcpp link I assume that's where you're buying from?
PCPartPicker Part List
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor (€179.90 @ Amazon Deutschland)
Motherboard: Asus PRIME H610M-E D4 Micro ATX LGA1700 Motherboard (€102.90 @ Alternate)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (€72.90 @ Alternate)
Storage: Western Digital Blue SN570 1 TB M.2-2280 NVME Solid State Drive (€96.90 @ Amazon Deutschland)
Video Card: PowerColor Radeon RX 6600 8 GB Hellhound Video Card (€377.99 @ Mindfactory)
Case: BitFenix Nova Mesh SE ATX Mid Tower Case (€46.80 @ Amazon Deutschland)
Power Supply: Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply (€71.44 @ Amazon Deutschland)
Total: €948.83
Generated by PCPartPicker 2022-04-09 11:35 CEST+0200
https://linustechtips.com/topic/1423638-building-my-first-pc/#findComment-15343298
