Hyper 212+ Fan Replacement Question
if he is willing to get ugly noctuas and dosen't care how they look why would you recommend worse fans? :D
Worse?
I had noctua NF-F12s and switched to GTs and they're quieter/give around the same temps.
GT's are EOL for quite some time now. (except the 500rpm version)
You can get them still on frozen CPU/ncix / amazon most of the time, and GT's are better than nf-f12's in the testing I did when I switched, and in martin's liquid lab testing:
http://www.overclock.net/t/1389355/fan-testing-round-12-begins-thanks-to-cpachris-and-prymus-nb-e-loop-sp120-nf-f12-cougar-vortex-pwm-vortex-red-led-pirahna-ap-45
What model of Noctua will be the most efficient and quiet for replacement on my Hyper 212+? My second choice would be a red LED Corsair but not sure which model would be the best.
Thanks
NF-F12 or Eloops as Ninja said, please don't get corsair though.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
