Do i need a fan hub
Solved by Thomas CG,
Your motherboard seems to have 5 fan headers and 1 AIO pump header, depending on the number of fans you plan to put in you case you might need either a Y splitter or a fan hub.
Featured Topics
ThankGodItsFriday ·
frostymelts ·
Posted in Troubleshooting0 -
1
RevGAM ·
Posted in Custom Loop and Exotic Cooling4 -
JakubR88 ·
Posted in Power Supplies6 -
2
2
4
4
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
