Hi guys.
I purchased used tablet but few days ago I noticed this tiny gap on top edge of the Surface.
Then I thought the battery is swollen but can not be,battery is on the bottom part of the Surface and screen pops out at the vertical edges of the Surface when battery is swollen.
So my assumption is someone worked something inside and did not glued the screen proper way, or it just popped out for some reason but for  Christ sake please let it not be the "famous battery issue".
Surface Pro 5 1796 first angle
Surface Pro 5 first angle
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
https://linustechtips.com/topic/1422873-surface-pro-5-1796-screen-issue/
