HI yall, so i have this soundbar and it works fine at first and the soundbar has a mic in and audio out jack built in and i tried it  it works great BUT after that i tried to use the soundbar it does not work any more it is just soooo annoying , does anyone have any idea how to fix this ?
I have tried fixing it several times but it just does not want to work i tried sorftware issue hardware issue but non of that work.
btw the soundbar is SONIGEAR u300 I also cant find anything at google that helps.
https://linustechtips.com/topic/1422860-soundbar-issue/
So it's broken? Is it still under warranty? Contact the manufacturer, maybe there's a way to reset it?
https://linustechtips.com/topic/1422860-soundbar-issue/#findComment-15337594
