If my pc cant reach 144fps and my monitor is 144hz should i limit it to 120fps and underclock monitor to 120hz or leave it uncapped?
Solved by Alex Atkin UK,
2 hours ago, PLSHELPME123 said:just cap? no underclock on monitor or anything?
Make sure your monitor refresh rate is no higher than your frame rate unless you can tolerate tearing or stutter. Just bear in mind that for the best response times when competitive gaming, you'd have to put up with it as vsync will add some input latency so you might want to keep that off and even uncapped.
This is why G-Sync/Freesync is so great, you can enable vsync without too much of a penalty and avoid stutters.
