problem with my second monitor help
10 minutes ago, cekko said:my cpu is not an "f". how can i activate the thing in the bio
This feature may not exist on some motherboards, but looks like yours does support that. The setting is usually called "iGPU Multi-monitor" and is usually in the Chipset configuration section, in Advaced tab. You can look up your motherboard manual and see if it helps you to find it. If it does exist, enable it and check if it helped.
Featured Topics
1stef ·
Posted in Troubleshooting0 -
Steiger2010 ·
Posted in Graphics Cards1 -
ABADDON Aamir ·
Posted in Displays1 -
1
1
PDifolco ·
Posted in Graphics Cards3 -
HARDWELL9191 ·
Posted in CPUs, Motherboards, and Memory5 -
ChrisLoudon ·
Posted in Laptops and Pre-Built Systems1 -
midix ·
Posted in CPUs, Motherboards, and Memory2 -
2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
