I'm thinking to switch to gaming laptop as my "desktop pc" because it's portability. I was looking for either legion 5/5 pro or rog strix G15/17 to play in my 200hz 1080p monitor. What do you guys think? I'm open to any suggestions and my budget is around CAD$1750.
my current pc specs :
Amd ryzen 5 3600
16GB Ram
Gtx 1060 6gb
256GB m.2 ssd
2tb HDD
240mm Liquid Cooled
https://linustechtips.com/topic/1421812-need-help/
Amd ryzen 5 3600
16GB Ram
Gtx 1060 6gb
256GB m.2 ssd
2tb HDD
240mm Liquid Cooled
I really don't like gaming laptops. They are usually very clunky and don't usually last the longest time. Why not just switch to a SFF build?
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
https://linustechtips.com/topic/1421812-need-help/#findComment-15330774
I travel twice in a year to my home country and it's kinda a hassle bring an sff build. I don't have a pc back home so I was thinking a gaming laptop that I could bring anywhere would be nice.
https://linustechtips.com/topic/1421812-need-help/#findComment-15330823
What kind of performance do you want and how it compares to your current setup?
https://linustechtips.com/topic/1421812-need-help/#findComment-15331007
I want the one that either matches my pc or even better if you have any recommendation. cause I mostly just play forza 5, nba 2k and a little bit of valorant.
https://linustechtips.com/topic/1421812-need-help/#findComment-15331167
I've had a few lenovo legions and they're great, I recommend them to everyone looking for a laptop
My recommendation would just be go to Lenovo Legion's website, and pick out a laptop
You could very easily get a laptop with a Ryzen 5 and a 3050ti or even a 3060 in that budget, both of which will definitely out perform a 1060
https://linustechtips.com/topic/1421812-need-help/#findComment-15331180
In that case pretty much any GPU starting with RTX 3050 which is on par or a bit faster than your 1060.
CPU-wise - Intel i3 12100 matches or outperforms your 3600, so go 12series+ if you can.
AMD 5600H and up - should be similar story
RAM: 16GB
Edit:
My bad, mobile RTX is a ‘step down’, so Desktop 3050 (initial suggestion) would be Mobile ~3050Ti~3060
https://linustechtips.com/topic/1421812-need-help/#findComment-15331225
RAM: 16GB
will I get an average of 100+ fps on forza 5 1080p and medium/high settings?
https://linustechtips.com/topic/1421812-need-help/#findComment-15331243
How was your legion? any problems with it?
https://linustechtips.com/topic/1421812-need-help/#findComment-15331244
