6 minutes ago, Biraj Lamsal said:
my pc doesn't has wireless
Get a WiFi adapter
edit: link to recommended one
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
https://linustechtips.com/topic/1420851-network-problem/#findComment-15323910
no, you have to buy parts no matter what you do.
1) Buy a wireless card for your PC
2) Buy a longer ethernet cable (best answer, if it would work to run the cable)
3) (dumb solution) buy a crossover ethernet cable, and plug the laptop into your PC and set up ICS on the laptop.
(Don't do 3, it's the worst idea.)
https://linustechtips.com/topic/1420851-network-problem/#findComment-15323913
I think many years ago your ISP could actually provide you with one in the late 00's/early 2010's.
You don't have to spend much on one like someone previously suggested.
Easiest thing to do and find would probably be a cable though, see if anyone has any laying around, I got one from my neighbour long enough to run down my chimney with enough slack to tie around a elephant's neck 10 times over.
https://linustechtips.com/topic/1420851-network-problem/#findComment-15323943
You can always move your PC closer to your router/modem. My suggestion is to have a wired connection. If you go wireless, don't expect a great connection unless you have a really good router and receiver. You'll have higher ping regardless.
Read before asking for help  |  How to respond to a no POST or no power up situation  |  Don't ask to ask, just ask  |  The XY Problem  | Don't just say "Hello" in chat  |  How do I ask a good question?
If my post helped, please give a 'reaction' using the heart 🤍 in the bottom right.
Make sure to quote posts or tag the person with @[username] so they know you responded to them!
F@H Contribution
BOINC Contribution
HeatWare
"The only difference between a problem and a solution is that people understand the solution."
"Give people permission to make mistakes and the obligation to learn from them."
“The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice.” - Brian Herbert
"People will never truly understand something until it happens to them."
"I usually give people more chances than they deserve but once I'm done, I'm done."
CPU AMD Ryzen 7 3700X  |  Motherboard Gigabyte X570 Gaming X  |  RAM Corsair Vengeance LPX 2x8GB 3600MHz  |  GPU ZOTAC GAMING GeForce RTX 3070 Ti Trinity OC |  Case BitFenix Ghost  |  Storage HP EX920 1TB, Samsung 840 EVO 250GB, WD Black 8TB, Seagate Barracuda 4TB  |  PSU Seasonic Prime GX-750  |  Displays Lenovo ThinkVision P27q-20, Dell UP2716D  |  Cooling Noctua NH-D15  |  Operating System Windows 10 Home
https://linustechtips.com/topic/1420851-network-problem/#findComment-15323950
