Clicking noise from GPU (rattlesnake noise)
Hey guys, I'm getting some clicking noise from GPU randomly (not constant) while idle. When I increase the fan speed to 60% or above it is gone or very rare. It is a HP Prebuilt and It has been just over a month getting the built and experiencing the issue for the past two weeks. When I contacted HP Support, they want me to "RESET my Windows" ,"RESTORE my Windows" and do "CLOUD RECOVERY" on my PC. I can't do that for their pointless troubleshooting.
The noise is not constant, for every 2 minutes it comes like for 5 seconds while the fan speed is at 30% at idle. I checked the case and there was no external wire hitting the fans but I haven't removed the gpu to check futher. Let me know what you guys think.If you listen closely you can hear the noise, ignore the fan noise.
Thanks!
probably fan isnt alligned perfectly.
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
any workaround for that?
I don't hear anything out the ordinary till 20 seconds when I hear two silent thumps, is that what you're referring to?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
No you can clearly  start hearing from 10th second, its like sparking sound. Probably you might have to listen closely.
Coil whine?
13 minutes ago, 191x7 said:
Coil whine?
I was confused as well if it was coil whine or due to fan so I shutdown my PC and spun the gpu fan with finger and heard a slight click noise. So I think its due to fan. But not sure.
I was wondering if it was due to fan how could I eliminate it.
