internet speed problem
Solved by 191x7,
5 minutes ago, RedMantisFPS said:So what im gathering is that there is no router on the current market that can push more than 1gbps from its rear 4 ports. That if i want more than 1gbps i will have to get a wifi 6e expansion card
No, you can get a router that has more than 1Gbps on the ports and you'd have to connect it to the wan ports of the first one.
Hm, some routers allow the use of the WAN port as a lan port. Maybe check that?
