DRAM LED on Motherboard with No Display Output
On 3/26/2022 at 2:28 AM, Lord Nicoll said:oops sorry for not replying sooner.
That's a somewhat older CPU and board, but I haven't heard of sandybridge just dying like that so it'd be odd, but possibly, however I'd be more thinking RAM, can you get a new DIMM cheaply? Probably be the better option, cheapest DIMM you can find to see if those two DIMMs but it is a little odd for two DIMMs to die together without something else killing them, which is why I thought maybe it was the CPU. I would suggest also looking for the lowest end LGA 1155 CPU you can find, a celeron or something like that, to test if it's the CPU. If new memory and a new CPU still don't post then it's probably the board. I would also suggest seeing if your board has BIOS flashback, it'll let you update/rewrite the BIOS of the board without the computer needing to be on or posting.
Ok so I will try getting new DIMMs. Thanks for the help by the way.
