General (Specific) Question
NextraMia
I have a 1440p monitor but when I go into settings it's capable of 4k as well on default settings.
Would it then be better to use 1440p 240hz (it's 240hz) or go for the 4k setting on 60hz?
// It is my secondary monitor and not my first so I won't be gaming on it //
CPU: AMD Ryzen 9 5950X ||| GPU: Gigabyte GeForce RTX 3090 GAMING OC ||| Motherboard: Asus Rog Crosshair VIII Dark Hero ||RAM: G.Skill Trident Z DDR-4400 CL16 ||| PSU: Corsair HX Platinum 1200 W 80+ ||| Case: Lian Li - O11 Dynamic Evo ||| Storage: 2x Samsung 980 Pro 2 TB NVME SSD ||| Cooling: (CPU: EKWB RGB 360 AIO) (Case-Fans: Lian Li SL-120 Infinity)
If it's 32 inch or higher I would use 4k, under that it's barely noticable so I would recommend a higher refresh rate. And ofc it's up to you, so just check both and see which you like better.
that would just be your preference, if its not used for gaming I would use it in 4K just to make it nice and crisp for reading or watching videos.
Also does it say 4K 60 on the monitors on board options or in windows. I had a monitor a while back witha cheap HDMI cable and it allowed me to pick 4K even though the monitor was only 1080P. I think the cheap HDMI cbale skip on some of the communication wires.
CPU: Ryzen 5 2600
GPU: RX 570 4gb
RAM: 24gb of cruical and Adata mix
The rest is trash
If you're not gaming in it then 4K 60 will be just fine.
It would be good if you mentioned the brand and model of the monitor. Any monitor is "capable" of 4k through superresolution techniques, but if it's a 1440p monitor then it can't truly display 4k and it will just be downsampling and image rendered at a higher resolution (in games) or display some weird sub-sampled mess likely on the desktop, because it doesn't have the pixels to display all the required unscaled detail.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
It's more of personal preference. If it's me I would keep native resolution for clarity. Sure, 4k gives more real estate but I wouldn't like blurrier text as a tradeoff.
PC spec: CPU: RYZEN 9 5950X | GPU: SAPPHIRE NITRO+ SE AMD RADEON 6900XT (Undervolt to 1045mV) | MB: MSI MAG TOMAHAWK x570 RAM: G.SKILL TRIDENT Z NEO 32GB (2x16GB) DDR4-3600 (OC to 3800 14-15-15-25) COOLING: NOCTUA NH-D15, BE QUIET! SILENT WINGS 120 & 140mm| CASE: IN-WIN 707 | 5.25" BAY: LG WH16NS60 INTERNAL BLU-RAY OPTICAL DRIVE | PSU: SEASONIC PRIME PLATINUM 1000WUPS: POWERSHIELD COMMANDER TOWER 1100VA
PERIPHERALS: KEYBOARD: CORSAIR K95 PLATINUM XT BROWN SWITCH | MOUSE: CORSAIR SABRE PRO WIRELESS | CONTROLLER: PDP AFTERGLOW WIRED CONTROLLER, DUALSENSE
DISPLAYS: LG 34GN8502x DELL S2721DGF | LG C1 48"
HT & audio stuff:  AVR: MARANTZ SR7013 | STEREO AMPLIFIER: YAMAHA AS-501 | SPEAKERS: DALI OBERON 7 & DALI ZENSOR 1 & 2x SVS-SB2000 | HEADPHONE DAC+AMP: TOPPING L30+E30 | HEADPHONE: SENNHEISER HD6XX, BOSE QUIETCOMFORT 35 II | MICROPHONE: AUDIO-TECHNICA AT9934USB | BLU-RAY PLAYER: PANASONIC UB820
AOC AG273QZ
i already have a 4k monitor as a main monitor but was just wondering if upscaling or what ever it's called is worth it for a little bit extra sharpness (in exchange for 240hz)
5 minutes ago, NextraMia said:
AOC AG273QZ
That monitor doesn't have real 4k. Yes there's probably some GPU setting to upscale it, but it doesn't make things look much better, especially since it's 27 inches and not something big.
