I have a 5 year old pc that just needs replacing due to me needing higher specs and I am looking to sell as a whole unit but I am struggling to give it a price if I could get any help on what it might cost that's would be amazing. It's been used pretty frequently.
My specs
Case: corsair cc-9011048-ww carbide series air 540
Motherboard: gigabyte Ga-z170x ultra
Cpu: Intel i7 6700k
Gpu: geforce gtx 1070 founders edition
Ram: Corsair Vengeance LED 16 GB (2 x 8 GB) DDR4 3000 MHz
Psu:Corsair CP-9020091-UK RM650x 650 W 80
Thankyou
https://linustechtips.com/topic/1418303-old-pc-pricing-help/
Quality power supply, decent motherboard even if it's on the old side. Good, fast ram.
How much storage space?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1418303-old-pc-pricing-help/#findComment-15305838
At a glance I'd say around $800, with most of the value in the GPU
https://linustechtips.com/topic/1418303-old-pc-pricing-help/#findComment-15305839
If it has a 500GB - 1TB of storage, I would ask 800 and expect around $700-$750.
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    BenQ MOBIUZ EX2710Q 27"
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
https://linustechtips.com/topic/1418303-old-pc-pricing-help/#findComment-15305845
I would say 800 in good condition and if it’s worse then 650 or 700 and if ur looking to build a new pc this would be a nice pc that would last you a while: https://pcpartpicker.com/user/Pcbuild12123/saved/#view=Jtsh7P and the ram is near the bottom since I had to add it as a custom part since it wasn’t in the database. You can change it to a 12400f and use the stock cooler if u want but that  stock in box cooler wont withstand more heavy tasks without going over 90 degrees Celsius.
https://linustechtips.com/topic/1418303-old-pc-pricing-help/#findComment-15306041
$155 for single channel DDR5? Even dual channel doesn't give hardly any boost over DDR4.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1418303-old-pc-pricing-help/#findComment-15306254
