!PROBLEM! On a production raspberry pi 3b+ apt not working
Solved by Jarsky,
It looks like your dpkg is damaged from all those dpkg errors.
First remove any 3rd party PPA's, you can check in the sources to see if you have any additional config files, e.g
ls -la /etc/apt/sources.list.d/
Or you can check if you have any in your primary apt sources.list
cat /etc/apt/sources.list
Once you've confirmed that is only the official repos for your distro, then try clearing dpkg and rebuilding it with APT
sudo dpkg --clear-avail sudo dpkg --configure -a sudo apt-get update
